I have a Miller 250D kubota would like to test SR1 to see if it is bad
发表于 2022-3-12 15:51:28 | 显示全部楼层 |阅读模式
How do I test the SR1 on an miller 250D?
Reply:Here you go. Be sure to disconnect it before testing. If you need a new one they are cheap enough.  https://weldfabulous.com/miller-0357...e-40-amp-800v/Miller Multimatic 255
GMT+8, 2025-12-18 19:12 , Processed in 0.108661 second(s), 18 queries .
