Millermatic 211
发表于 2022-3-12 15:51:28 | 显示全部楼层 |阅读模式
Hey fellows, I need a board for my millermatic 211 auto set. I’ve had it four years and the board just quit on me. Anyone know where I can find one other than miller?Miller 211Miller Dynasty 210
Reply:I don't believe there are any aftermarket boards out there for the 211's....  you might be able to find a pull on ebay.amz/fb... but it won't be much better than your board was two minutes before it quit
I would pull the board and see if you can find a repair place that will fix it... there are a couple common issues with the 2ng gen 211's that blow a couple components...  I'm guessing this is a 2nd gen 211...?
Reply:Yes it is. It was only a month out of warranty when it blew and miller wouldn’t work with me. The board looks really clean doesn’t look like anything is wrong. But they said the board was out and it would cost 700 to repair it. So I thought I would check here.Miller 211Miller Dynasty 210
Reply:Here's a couple pics of the last 211 I had blow... this one took out D45 and D6 diodes... sometimes (most times) it takes out a transistor and maybe a resistor also... but this one didn't....
Reply:Thanks for the info. My father in-law has it now trying to fix it. I will tell him to take pics and I will post them. I never had a problem with this welder until I hooked my aluminum spool gun and in ten minutes it went down.Miller 211Miller Dynasty 210
Reply:hmmmm. don't recall anything about spoolguns causing issues???  mine have not ran spoolguns.. so yours may be something different???Oh, the transistor tor the right and down(from the diodes/in the heatsink) is the one that usually blows( I forget the board number) but it's a to220 case or similar IIRC....
Reply:Curious, where was machine purchased at  ?? We had a issue with a first generation Miller  XMT 304. It was 6 months out of warranty and our welding supplier repaired it under warranty. Machine was purchased from them. Sent from my iPhone using Tapatalk
Reply:It was purchased at Airgas. They didn’t want to help much. And we spend a lot of money with them. I bought my other two home welders from another weld supply store. They have been more helpful.Miller 211Miller Dynasty 210
Reply:I agree. I won’t buy another welder from them for sure. Luckily we have young’s welding. It’s a smaller family owned shop, they just can’t get low enough on they’re gas bottles for us to use them solely.Miller 211Miller Dynasty 210
Reply:Glad I bought a first generation 211 when they were phasing them out for the 2nd gens. It was $999 with a $200 mail in rebate. Purrs like a kitten.
Reply:is a first generation 211 the one with the suite case handle in the top center of the case?lincoln 125spdayton 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dkubota b3200 FEL BHof course duramax diesel
Reply:Check here -https://innovatcorp.com/pc_board_repair_price_list
Reply:This is a picture of the board. And I hear ya show dog 75. I wish I had the first gen. I can’t believe this one sucked.
Reply:I smoked one of those 211's, but it was my fault for not really paying attention to the duty cycle.
Reply:shame on miller for crapping on you so close out of warranty.
Reply:Do you know the values of these components? I refer to D6 and D45.
GMT+8, 2025-12-18 19:24 , Processed in 0.093293 second(s), 18 queries .
