How to weld bottom with downhand cellulose.
发表于 2022-3-8 15:51:24 | 显示全部楼层 |阅读模式
Using a pipeliner200D, what setting are you using for a successful cap on the bottom,  that matches the top? I have to use a 5/32 8010 for this specific test.
Reply:Depends on your skill set But try it at middle gear 60 to 70 fine current Or turn it up on the high side and turn fine current down to 30 to 35
Reply:Wall thickness and pipe diameter would behelpfull
Reply:Maybe a photo of your stringer and hot pass too
Reply:Maybe a photo of your stringer bead and hot pass
GMT+8, 2025-12-18 16:46 , Processed in 0.091521 second(s), 18 queries .
