Has anyone here ever had a Magneto rebuilt
发表于 2022-3-7 15:51:19 | 显示全部楼层 |阅读模式
Has anyone here ever had a Magneto rebuilt? I know that there are several makers and models of these units but I am primarily looking for ballpark costs.Do you know if they send you a rebuilt unit and you send them your unit to rebuild or not ?Also has anyone disassembled one or knows how difficult it is to rebuild one yourself ... with reasonable skills.Finally has anyone converted from the Magneto to a distributor and how difficult/expensive is that !!!!!Thank you all
Reply:Try your local airport they use Magneto's on aircraft. They not hard to rebuild the biggest problem is get the magnetic recharged. Dave
Reply:Magneto off of what?The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-18 16:59 , Processed in 0.093930 second(s), 18 queries .
