Miller Max Star150 s troubleshooting
发表于 2022-3-6 15:51:21 | 显示全部楼层 |阅读模式
How do folks having problems with this Max Star 150 s it has some output not enough to burn a rod, when plugged up to 110 blue light flashes maybe twice then stays on any ideas thamks
Reply:What size and type rod are you using? What amperage breaker and wire is the circuit you're using? Try grinding the steel clean where the ground clamp is attached? Make sure the connectors on the machine aren't loose.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power
) Hobart MIG
GMT+8, 2025-12-18 19:27 , Processed in 0.105186 second(s), 18 queries .
