Something NEW!! A DIY Welder,, BUT, I Want DC, Not AC,,,,,
发表于 2022-3-4 15:51:17 | 显示全部楼层 |阅读模式
Here is an instructional video,, on how to DIY your next welder,,Which of the "Big Three" welding machine companies will be the first to go under??(probably, Harbor Freight will survive,,,?? )The welding machine DIY starts at 3:41 minutes.I wonder, if you use Potassium Chloride, instead of Sodium Chloride, will the welder output convert to DC!!?? What should I use as a cabinet,,?  I am considering a "takeout" carbonator,,
GMT+8, 2025-12-19 05:08 , Processed in 0.086793 second(s), 18 queries .
