Recommend me a good drill bit set for metal
发表于 2022-3-4 15:51:16 | 显示全部楼层 |阅读模式
Under $100....and go!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:http://weldingweb.com/vbb/showthread.php...ight=drill+bitEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:There should be plenty of  average quality bits for under $100,I have heard the cobalt bit set  from HF is not bad at all.If you want your bits to last a long time,I suggest you  use them in a drill press(if possible) with stock well clamped, and definitely use a good quality lubricant like Walter coolcut. I hate to use my good quality  cobalt bits in a cordless drill,they are so brittle they break in no time, then I end up with an incomplete set.
Ken from ontario,Canada.
Reply:If your using them in a keyless Chuck , I would use mechanics length with the 3 flats . I like the Viking brand. My lws ( Mississippi Welders supply) has them for 80$ right now. Maybe check Weldfabulous, since they are the online sales of mws.
Reply:Drillco brand drill bits are by far the best bits I've had. I have drill thousands of holes insteel ranging from an eighth of an inch to half an inch. What steel thicknesses ranging from an eighth of an inch to 3 inches thick. As long as you keep them oiled and don't go too fast they last twice as long as the Fastenal brand. I've also had pretty decent luck with the Milwaukee drill bitsSent from my XT1585 using TapatalkVantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:https://www.amazon.com/Viking-Drill-...QQ51XCJYABFDZV1/16" to 1/2" by 64thseven made in the USHow do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
Reply:Norseman. I have used these for 15 years, on my 2nd set and I'm not gentle on drill bits.Eventual master of the obvious, practitioner of "stream of consciousness fabrication".  P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:I spent years as a toolmaker then some more years as a CNC programmer and for home use and I believe professional use you can't beat the 115 piece Cobalt set from Harbor freight for price and durability, IMO. I've had mine for a year and used them many times and they've never disappointed me. 😃They come on sale for $90 regularly.http://m.harborfreight.com/115-pc-co...set-61886.htmlGood luck!MikeSent from my XT1254 using Tapatalk
Reply:If you ever drill stainless, look for cobalt or zirconium nitride coated. Drive across the border to a Canadian Tire when they have them on sale and you'll make out like a bandit with the 78 cent dollar.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I purchased the HF cobalt 115 piece set about 3 years ago. Outstanding quality for the price. I've drilled hundreds of holes with them and still going strong. Used for 304,1018,4130,cast,brass,bronze and 6061.Norseman quality bits:http://www.harryepstein.com/index.ph...ct_detail=2604
Reply:I'm not here to recommend any particular set of bits, but to advise you to stay away from the hype of all the crazy alloy and coating marketing BS....    I usually recommend nothing more than good bright HSS bits, but do agree a cobalt alloy bit is nice, if from a quality manufacturer.    Forget coatings, they're worth nothing unless you're in the business of repetitive high-speed drilling like in some sort of production environment.
Reply:Are the Norseman/Viking bits cobalt bits?Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:norseman/ viking is viking/ norseman. same stuff from my readsand both are great and what i demand. there is a long running joke about how i "took gold in the 1990 something (insert year of your choice) hand drilling championship." and i do feel that i am great at drilling holes with a handheld. feed, speed, lube (mike o cut) and telling myself "i am the drill press" with norseman or viking bits renders great holes.bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Originally Posted by M J D
Yes, Viking seems to be better priced than Norseman, as far as I know, same manufacturer.
Reply:Just ordered these Norseman Drill Bits 44170 Ultra Dex Type 240-UB 135 Degree Split Point Magnum Super Premium Jobber Drill Set (29 Piece) on Amazon for $71.92Last edited by N2 Welding; 12-03-2016 at 02:27 PM.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:Champion Brute bits.  Just over 100 for the 29 piece set on Amazon.  Worth every penny. Usually get over 100 holes between sharpening with the 29/64 bit on 316ss.  Gotta keep them cool though. Sent from my SM-N910P using TapatalkMultimatic 200Ellis 1800Haberle S225 9" cold sawMM 300;  Spoolmate 30A w/ WC-24TB 302GDynasty 280 DX Tigrunner
Reply:Just my two cents...sorry for bumping...I drill thousands of holes annually in most metals and some plastics. Yes, I do "keep score" regarding how many hundreds of inches of material a certain drill bit can penetrate. My shop machines everything from plastics to steel that is nearly 60 Rockwell C.Sharpen drill bits? I only sharpen drill bits that are larger than diameter 0-1/2". Used correctly many bits have "collapsed" flute edges by the time their point is worn to the need for sharpening and will have a problematic performance after sharpening. In essence; they are not worth grindng.In an emergency I will use a drill point gauge and grind one by hand. That is a skill that is all but lost I guess and even I am not a fan of it. As soon as a replacement is available that bit will hit the scrap can.None of the "home shop" drill bit grinders I have seen will make a correct point on a drill bit. Drill bit grinding is every bit as serious as the grinding of other cutters and requires specialized machinery that one does not purchase for a few hundred dollars.So, even though there are at least three (03) established and common point angles and web and helix types and materials from that drill bits are made; what would I recommend to someone who wants to drill everything from soft materials all the way through steel hardened into the high 40's Rockwell C?Very simply this: Select drill bits made from M42 Cobalt like this types https://mechanicguides.com/best-cobalt-drill-bit-sets/ alloy high-speed steel with a heavy web and a 135-degree split point or "crankshaft grind" as the old fellows  call it. Purchase such tools only from American or a select few European makers.TiN (Titanium nitride) coating? Only if you do as I do and expect a drill bit to produce a few hundred to a few thousand holes. Otherwise you might as well pour your money down the sink. Carbide? Only for very special applications with super accurate machine spindles.The common twist drill bit is still the most efficient metal removal tool ever designed regarding cubic inches/horsepower/minute. It is also the most abused metal removal tool ever designed.McMaster-Carr pricing is fine. Another source is Suncoast Precision Tools https://www.suncoasttools.com/The worst gimmick? Anything that is TiN coated and made in China or India. Buy cheap, expect garbage. A plain Jane American simple high-speed steel uncoated drill bit will outperform these gimmicks any day.Just some suggestions and one good video from Youtube, that I hope will help.
Reply:I have a $100 precision twist set in HSS, as well as a $80 Harbor Freight cobalt set. They're both equally good at drilling holes... The downside is sharpening the harbor freights is tough because I use a drill doctor and it pretty much doesnt work for those bits unless you have 4 hours to kill.Last edited by BrooklynBravest; 11-13-2018 at 05:50 PM.www.FirehouseFabricators.comZachMillermatic 255Lincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:drill bits 1/2" and up were from new york twist drill and cincinnati tool. anything smaller was disposable. we had a machinist who sharpend the bits on an antique milwaukee pedestal grinder.i.u.o.e. # 15queens, ny and sunny fla
Reply:Another recommendation for Norseman.  I’ve been using their Magnum drills for over 30 years.  Before that I used Butterfield and Cincinnati Twist when I had my machine shop.Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Reply:Back when I was an apprentice tool maker we made custom drills with HSS for the manufacturing shop to use in production, lead man used to tell me we had to make them faster and cheaper or they would  buy them , Years later i was working in a sign shop and I sharpened some drills   on the grinder , owner said not to do it as the last guy couldn't sharpen them to save his life ,they all wobbled  he was amazed when they drilled true holes. only HF drill bits I used were crap,Boss though he got a good deal on on a set of that rainbow colored junk, they would round over on the first or second hole.
Reply:See if you can find a Cleveland Twist drill index in cobalt for under $100.. Cleveland makes about the best drills I've ever seen,  besides the inserted or solid carbide drills.. Precision Twist Drill is another great brand, might be cheaper than the Clevelands. Also do yourself a favor a purchase a carbide spot drill while your at it .Last edited by brucer; 11-15-2018 at 12:37 AM.Do any of ya'll use the stepped hole cutting drills and if so what brands do you use?
Reply:I use them a fair amount. 1/8" and less. The Irwin used to be pretty good, Lennox seem ok, klein are really good. Going to try a viking brand, should be here tommorow, if so I will post how it performs. They also work well for debburring holes and round tube.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Oh yeah I had not even thought about using them to debur tube and pipe.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:I bought a few sets of step drills at HF (drillmaster) a few years ago. They out perform the greenlees I use at work.
Reply:The stepped drills from Ruko are very good, but they are not cheap, best prices I have seen are on amazon.de. Irwins are also good. Sent from my iPhone using TapatalkMiller Dynasty 280 DX TIGRunnerFronius Transsteel 2200
Seriously I figured they would be junk.I am still waiting to hear how the vikings worked for M J D
Reply:For the record: DRILL HOG, despite their two American flags on their logo, are made in China. Deceptive advertising at best IMHO!
Reply:I've got a few of the TEMO brand carbide steps and so far they are pretty dern good
  haven't broke one yet but i tend to be a little careful with drills in general... although anything below a 1/16th in a hand drill is just asking for it
https://www.ebay.com/sch/golden_coulee/m.html?_nkw=step
Reply:Back to twist drills. You might want to look at Cle-Line drill bits.   They are usually 135 degree split points and work extremely well on metal.  Bonus:  They are made in Seneca, SC.  Bonus 2:  They are not especially expensive.  Available at the usual places including Home Depot.
Reply:Thank you Fnord5 for that tidbit of info.  Taking notes.ronsii  I'll have a look at those as well.  Henry TY for bringing the two flags not made in good ol USA Hog wash Crap-O-La to our attention ...Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:I bought the drill hog m 7 off of ebay they are way to brittle I chipped the 3/8s in the mill. And snapped off several of them hand drilling, absolute garbage was going to warrentee them but all i will get is more crap that chip when they break through or snap off deep. Ihad a set of irwin max i really liked got dozens of holes out of each one. Replaeced them with another set just like them. they had changed the heat treatment and would snap off if you breathed to hard on them. All my hand drilling is done with a milwaukee hole shooter without the second handle. I have twisted the shanks on the harbor freight silver demming sets. nothing quite like untwisting your drill bit.Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:I don't think I've broken a single bit in the drill press since I slowed it down to 80 rpm. I do leave a little slack in the belts so they slip when it jambs. Hand helds of course are a different story...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:On the steel corrigated decks I've drilled thousands of holes with these for bang it's inserts all different brands usually Lenox but that's just what the supply house sent, they make sense in alot situations, most pressure and heat is on a initial hole after that it works like a annular cutter
Reply:Interesting... I didn't know they made them with a replaceable tip. I am currently looking at one that goes out to 1 3/8 and would like one that goes to 1.5" if they make them...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Replacable tips is kind of cool.  Ever break a tip off leaving the threads below the surface in the hole?Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:X2 for CLE-LINE, available at home depot and lowes, made in USA, good metal, sharp, competitive pricing to norseman.  I've had good luck with Milwaukee shockwave drill bits as well, but for pete's sake don't use an impact for metal drilling!  I'm also a fan of the harbor freight step bits, they last decently and one cannot go wrong for price per cut.  Use cutting fluid and go slow!  Learn how to sharpen twist drill bits by hand (not that hard, 30 mins to competence, draw reference angle line on tool rest with sharpie), and learn to read the chip for pressure.  Remember a hot chip (within reason) is taking the heat from the cut, when i use the step bit in thicker material the chips burn my arms if not protected.  P.S. I bought drill hog m42 bits and they aren't the worst, though far from the best - sharpen extremely well but tend to chip on the corners, they're better than most in the drill press and about average in a hand drill due to chipping.Last edited by SlowBlues; 12-09-2018 at 10:12 AM.
Reply:I bought a set of Viking mechanical drill bits made by Norseman and the have performed beyond expectation, I highly recommend them:https://www.amazon.com/Viking-Norsem...et+%2829+PieceLast edited by distrbd; 12-11-2018 at 12:26 AM.Ken from ontario,Canada.
Reply:https://www.wttool.com/index/page/pr..._shopping=trueForgot who makes them, but very good bits.  Actually ground properly.  Handy to have all the sizes, especially if you do a lot of tapping.
Reply:I have a funny HF story: when south, visiting grandpa in Santa Rosa, I stopped by the local HF store and needing some extra weight in my baggage to replace that of the canned salmon just dispensed, I could not help but buy an on sale 29 pc. super-duper drill set (tiN coated, of course) for $19! They MIGHT be useful as a nail, in something like balsa or perhaps used to remove hardened ear wax. Of course I knew better! Of course I couldn't help myself! I'm pretty good at sharpening drill bits but alas, they are still nails with a twist. Sure looked good, though...I've had a 29 pc. set of Hanson's HSS (now Irwin) for longer than I can remember. Most of the wear is dingle-berries on the shank. Though it is true that most of my work is with AL, still, they will pass on ready-teddy after I croak.SO...here's my offer to the OP's query, and cobalt to boot: https://www.amazon.com/Irwin-Tools-3...+drill+bit+setLast edited by Yofish; 12-13-2018 at 12:08 AM.
Reply:Walter makes a decent job site 29 bit set. A bit hard though so dont drop em or they chip
GMT+8, 2025-12-19 05:07 , Processed in 0.095752 second(s), 18 queries .
