Lincoln Ranger 10000 Parts
发表于 2022-2-28 15:51:17 | 显示全部楼层 |阅读模式
Hello all,  new to the group.  I try to lay dime but end up with welding crimes. Just kidding. Recently I just picked up a Ranger 10000 with about 500 hours, has the Kohler engine. However, it is missing the rear base plate where the battery goes. Was wondering if anyone could pour me in the direction of a used one.  I thought I would look before I try fabing one up, because that cost the hardest thing to find —-time—-.  It weird, the more I try to set time aside for stuff the harder it is to come by.  Anyways, thought I would give it a shot. Thanks much,Paul
Reply:Go here and browse as guest. Upper left hand corner select product / engine drives / browse to your ranger 10000. Dig a bit and get the part number you need.https://www.lincolnelectric.com/en/Service-NavigatorThen go here and put the part number in that you find above.https://www.shopwelderparts.comI use them all the time, They have a chit ton of parts and quick shipping. But the only way to navigate their site is with part numbers.Lincoln 330MPXModified Lincoln 225 TombstoneLincoln LN-25X-TVTMagnum PRO 250LX GT Spool Gun¼ Ton of Torches OFC-A / OFG-ASMAW FCAW GMAW Air Carbon Arc GougingEverlast 62i Plasma CutterIngersoll Rand Type 30 14HP#Freebird Welds
GMT+8, 2025-12-19 05:08 , Processed in 0.090178 second(s), 18 queries .
