CK alternative?
发表于 2022-2-28 15:51:17 | 显示全部楼层 |阅读模式
I’m looking for a water cooled torch to replace my CK #17 air cooled.  Will a #20 water cooled use the same sized consumables from the #20 air cooled?  What’s a good alternative to CK that is priced better?
Reply:No such thing as a #20 air cooled.  The torch that is the same size as the #20 (water cooled) that is air-cooled is called the #9.  The #9 and #20 share the same exact consumables, which are not inter-changeable with your current #17.Aside from CK, there's the cheap chinese/overseas ones you find on Ebay/Amazon.  I wouldn't call them a good alternative, but they do work.  There is also WeldTec/Tec Torch that is top-notch, but it's the same basic pricing as CK and a lot harder to find distributors for.  Just bite the bullet and get CK.
Reply:Looks like the #18 water cooled torch uses the same consumables as the #17.https://www.ckworldwide.com/products...r-cooled-torchhttps://www.amazon.com/Alffun-Consum...NsaWNrPXRydWU=---Meltedmetal
Reply:Yea the 18 shares the consumables with the #17 and #26, but it is "clunkier"/heavier.  Sometimes the weight is a good thing so you don't shake as much, but the size can get in the way for tight corners.
Originally Posted by BeeGee
That’sa great deal on those consumables!
Reply:https://weldingweb.com/vbb/threads/7...87#post8809587
GMT+8, 2025-12-19 05:12 , Processed in 0.125412 second(s), 18 queries .
