I have a 212 millermatic with very low hrs on it. I had to take it to a shop and have a circuit board put in it. I finally got it back after multiple excuses and went to use it for the first time but now it starts really slow then speeds up about half speed then slows down again and then it just stops. I tried to set the slow start but it doesnt work as shown. Any help on this would be greatly appreciated. Thanks
Reply:If it has low hours and you blew a board, I'm assuming it didn't run much. Inverter machines dont like to sit past a year without use.It could be a simple item, or it could be more damage from fixing the main problem.
Reply:You got it back from the shop, but it's not working properly....they need to correct that.Check out my bench vise website: http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT |
