Flowmeter advice
发表于 2022-2-28 15:51:16 | 显示全部楼层 |阅读模式
I recently purchased a Miller Multimatic 220 and need some advice on an economical, compact  Flowmeters for the TIG and MIG applications.  The welder came with 2 regulators but I would prefer to use  flowmeters for both.I'm presently modifying a HF welding cart to accommodate the 220 and set it up for 2 "Q" tanks.  I would like to keep the regulators/flowmeters inboard as much as possible since the tank area will be wider than the cart.  BTW, I was attracted to this particular cart because of the drawers and a compartment to keep my helmet somewhat protected.My research has me zeroed in on 3 choices:  (1) Harris 601-AR-580 PN3100575, (2) Harris 351-60-AR-580 PN3100331, and (3) Victor GRF-400-580.  Has anyone had any experience with any one of these?  I realize that these are historically American brands but many are now made offshore.  Any quality issues?
Reply:No experience with any of those, but the Harris are imported from Poland.  I didn't see a country of origin on the Victor, but their best seem to be made in Mexico now, and the less expensive models are from other countries.I've tried a lot of different flow meters in the past few years and for TIG I'll take a Harris 355-2 over everything else....made in the U.S. and only 20PSI output so it has the softest puff of gas when you initiate the arc.  Next I put the Victor 2425 and 1425 which are made in Mexico and 25PSI output, so still pretty soft puff on startup.  For MIG I don't mind the extra puff you get with the less expensive meters, which are usually calibrated at 50PSI output.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
GMT+8, 2025-12-19 05:17 , Processed in 0.117260 second(s), 18 queries .
