Brass radiator what kind solder and flux?
发表于 2022-2-26 15:51:17 | 显示全部楼层 |阅读模式
I have an old brass radiator.  It developed  a pinhole in the header tank today.  I rigged up a pressure tester and pressurized the tank to 15 pounds and it held so I am not concerned about running considerably less pressure and starting another leak. Now my questions.  I have a big soldering iron so I am going to use it.  I have some 50/50 solder (50 Tin, 50 Lead) and some old flux for acid core solder.  Is the flux the proper cleaner for the 50/50 solder or do I need some other?  Is my 50?50 suitable for radiator repair? Do be afraid to send me to NAPA to get the right stuff.
GMT+8, 2025-12-18 20:17 , Processed in 0.123361 second(s), 18 queries .
