4foot 48" or 1200mm framing square, where to find one?
发表于 2022-2-25 15:51:18 | 显示全部楼层 |阅读模式
I am after a 4ft framing square.  Same as the smaller 2ft framing square, just that its, well about 4ft long.  Never really measured it.  Anyway I used one at my last workplace and now I want to buy one for myself.  Can't seem to find any on the internet.   Guys at the new place didn't know what I was talking about, said they had never seen one before.So, anyone know where I can get one?
Reply:I don't know where you can get a 4 foot framing square but I know they make 48 inch T-square's, they are fairly inexpensive also.   Don't know if that would be helpful.
Reply:T square is offset top of T so it works easier on sheet goods. I'd expect a L shaped framing square to be awkward on the big stuff.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Drywall tee square?
Reply:1 agreeI have one when one For larger needs a have a transit Dave
Originally Posted by tapwelder
Drywall tee square?
Reply:With some 12ga or thicker x 3" flat bar build it yourself using A sq +B sq = C sq to get it at 90*.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:https://www.lowes.com/pd/Johnson-Lev...E&gclsrc=aw.ds
Reply:closest I could find...https://www.amazon.com/Draper-1200mm.../dp/B0034BHGTAhttps://www.amazon.ca/CH-Hanson-Alum...32663339&psc=1Last edited by whtbaron; 13 Hours Ago at 02:28 PM.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-19 05:10 , Processed in 0.075259 second(s), 18 queries .
