Miller Big 40 Carb/Fueling Issues
发表于 2022-2-24 15:51:21 | 显示全部楼层 |阅读模式
Long time lurker, first time poster.  Anyway, I've got this Miller Big 40 I picked up at auction that I've been working to refurbish.  It's got the gas continental f400a-612 engine in it and I ended up just replacing the carb since the original was totally trashed.  I made the mistake of not noting the position of the governor and vacuum linkages (I think that's what these are) and now I can't get it to pull any fuel into the bowl or fire up.   Best info I could find on this engine is a scan of an old weldmart document (https://www.weldmart.com/main/techni...d_overhaul.pdf), but I haven't had luck so far.  Any advice?
GMT+8, 2025-12-18 20:12 , Processed in 0.101334 second(s), 18 queries .
