ESAB Powercut 1300 error code 15
发表于 2022-2-23 15:51:19 | 显示全部楼层 |阅读模式
I have a Powercut 1300 that is displaying error code 15 (bus charger failure, primary bus not up to voltage). What I've read seems to indicate that this fault code must be cleared by a service center... is that correct? Power cycling the machine (total disconnection from power) doesn't clear it.Thanks,AndySent from my SM-G950U using Tapatalk
GMT+8, 2025-12-18 20:12 , Processed in 0.099727 second(s), 18 queries .
