Squaring off end of pipe?
发表于 2022-2-19 15:51:39 | 显示全部楼层 |阅读模式
Spiral wound pipe.  Using a pipe wrap around vs one of those flange wizard mitre markers?The weld seam of the spiral wound pipe is a pain in the ***. I wonder what those flange wizard mitre markers are like at squaring up the ends of pipe at 90 degrees. Was thinking maybe it is worth having one?
GMT+8, 2025-12-18 20:12 , Processed in 0.121468 second(s), 19 queries .
