How attach hot/cold lines to CK20?
发表于 2022-2-18 15:51:28 | 显示全部楼层 |阅读模式
Which of the Fail-Safe Connection gets the BLUE and BLACK?  Does the short one get the BLUE?  Does it make a difference?  If so, CK really needs to label.  Seems a little confusing since in my mind, those two are the hot and cold water connections, but instead one is a GAS connection and the other is the WATER IN connection.
Reply:blow through them.  The one that forces air out of the threaded power connection is the cold water in.
GMT+8, 2025-12-19 03:19 , Processed in 0.096205 second(s), 18 queries .
