Test method?
发表于 2022-2-16 15:51:18 | 显示全部楼层 |阅读模式
So I got one of those older 165a Chicago tig/stick combinations with hf start. No pedal, but I found a titanium pedal with the same connector. As I'm new to tig, and don't have a gas bottle yet, what's the safe procedure to test and make sure both the machine and the pedal are working on their own and correctly with each other? I have stick welded with the machine already. Hoping I can find out with a volt meter without taking it apart.
Reply:Opened both and traced the wires... not compatible, but a little soldering and someone that can tell me what to swap? Drawing up the diagram, will start a new thread with pics...
Reply:Right, I thought maybe this was a more correct place to ask. I've got most of it figured out, but there are things I'm unsure of that I'd like someone experienced with pedal wiring to make sure I don't screw the pooch.
Reply:Diagram of connector wiring, can't seem to be able to add multiple files?
Reply:Pedal wiring on slider pot
Reply:Pedal switch wiring
GMT+8, 2025-12-19 03:19 , Processed in 0.088596 second(s), 18 queries .
