Snow Scooper Edge Replacement
发表于 2022-2-12 15:51:20 | 显示全部楼层 |阅读模式
We get enough show here in Michigan to wear out the cutting edge of the snow scooper in about 1-1/2 winter seasons.  The rest of the scooper is in almost new condition, it is just the edge that gets worn out.  The scoopers cost ~$60, so I thought that I would just replace the cutting edge.  Below is a picture of my snow scooper.1. Snow scooper
Below are two pictures of the worn edge on the snow scooper.2. Worn edge 1
3. Worn edge 2
The following picture shows that even though the edge is badly worn the counter sink rivet in the countersunk hole is still holding.4. Countersink still holding
The first step for replacement is to drill out the old rivets using a #30 drill for the 1/8” rivets.5. Drilling out rivets
I was able to purchase 24” long U-Edge from Online Metals for $4.28 each0.0625" x 1" Carbon Steel U-Edge 1018 - Part #: 25693
Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE  31 MP & Lincoln 210 MP
Reply:6. Replacement edges
I had to cut down the 24” long stock to 20” to match my scooper. 7. Cutting edge to length
Below is a picture of a countersink tool as well as a countersink rivet. I recently purchased some of the tools from blindrivetsupply.com.Marson Countersink Drill Bit 1/8" Dbl End, $7.47 eachPart Number: BR-391018. Countersink rivet and tool
Here is a picture of the hole made by the countersink tool.9. Countersunk hole
I use counter sink rivets, when possible, but a conventional button head rivet will also work, provided that you drill the hole with a countersink.  The process of setting the rivet will drive the rivet into the countersunk hole. I have had trouble in the past with cheep rivet tools. This one is a quality one made by Marson and it still works fine after over 50 years.10. Installing Rivet
Reply:Here is a picture taken from the bottom of the snow scoop showing the head end of the rivet.11. Rivet installed
I used back up backup washers to give the rivets maximum holding power.12. Backup washer installed
I purchased four of the replacement edges so I should be set for a while.  -Don
GMT+8, 2025-12-18 17:58 , Processed in 0.092863 second(s), 18 queries .
