Sa 200 not idling up
发表于 2022-2-11 15:51:25 | 显示全部楼层 |阅读模式
200 not idling upMy sa 200 is not idling up when I strike an arc I have replaced several things on this machine and I'm down to the last of the core problems with it running correctly and I was hoping that I could receive some help in this welding community. I can and will post pictures. I have messed with the idle control rod and the governor a little bit but other than that I have no clue. Replacing the idle solenoid and replacing the PC board and the oil switch is all that I feel like I can do I also need help adjusting the governor and my idle screw is there anywhere I can get specs from? Please help guys thank you  If I can post pictures and video I willThis is a photo of my machine at its current idle while the machine is runninghttps://linksharing.samsungcloud.com/wTzq6fI5QSZiLast edited by Malachicousin33; 1 Day Ago at 07:17 AM.
GMT+8, 2025-12-19 03:19 , Processed in 0.112009 second(s), 18 queries .
