Wanted: CO2 regulator for welding
发表于 2022-2-11 15:51:24 | 显示全部楼层 |阅读模式
I have a 3-gas mixing system that allows me to mix argon, helium and/or CO2. I have 330 cf cylinders of Ar and He and a 50 lb cylinder of CO2. (These height match well.) I need a better CO2 regulator. Please note, I need to regulate the output to 30 psi. In particular, I cannot use a flowmeter. I don't need a heated regulator but would consider one. Please let me know, thank you.metalmagpie
GMT+8, 2025-12-18 17:59 , Processed in 0.103685 second(s), 18 queries .
