Repair suggestions
发表于 2022-2-9 15:52:36 | 显示全部楼层 |阅读模式
I have a fire place set that I have had for many years.  My wife accidentally dropped the poker and the top broke.  ( I forgave her if she makes Lasagna for my birthday this weekend). The material is not magnetic, so I'm guessing pot metal. It has a bronze finish but I'm sure it's not bronze. Suggestions on repair?  Silver solder, epoxy, trash can?
Reply:JB Weld.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Sure, it has saved a lot of equipment and have done some pretty sophisticated repairs.www.urkafarms.com
Reply:I had a busted plastic fan hub a couple weeks ago.  It was out of a Sears and bet if I tried could find it discount on the net.  Not sure how much it costs and didnt feel like digging for salvage so, too me 2 tries as the goo didnt really stick well to the plastic but 2nd I make a form, gue in with a little quicj, added 3 sheet metal screws for some mechanical anchor and poured the bub which was shattered all to it.  Prolly north of an ounce, couple table spoons full, all one piece again. Was a piece I use a lot, every day, misse3d it the minute it broke and now is obvious might not have been working right all along.www.urkafarms.com
Reply:braze it
Reply:I think you are right it is pot/white/zinc metal. What does the rest of the handle look like.---Meltedmetal
Reply:Like others have recommended, use JB Weld.  Epoxy (which JB is also) probably wouldn't hold like JB Weld.  Something different in JB, maybe the steel powder in it.  That stuff will mend a broken heart!
Reply:I would see if I had a metal tube or rod that would fit inside, rough up the inside and JB it.  Use the stuff that is 2 part makes gray epoxy, great stuff.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:I did a butt similar a while ago.  It was really clean about like that.  I massage the goo in both pieces and put it together with a weight. Look at a break under a glass, that tear added a lot of cross section to it. Clock it so it goes back the way it came apart and squeeze the stuff in the grains and it will be as strong as it ever was.www.urkafarms.com
Reply:The only fair resolution is to buy a lathe then machine it from brass.  Then silver braze the part to the shaft.Last edited by tapwelder; 1 Week Ago at 07:27 PM.
Reply:This was passable for the proximity of the parts.  So lasagna is nice, perhaps a lathe...  Or 3D printer.
Reply:Were welders here!   Freaking bust out some torches and braze it!  Cant believe im reading about JBweld....It seemed like a good idea at the time!
GMT+8, 2025-12-19 03:19 , Processed in 0.071667 second(s), 18 queries .
