Syncrowave 250DX coolant pump/fan problem
发表于 2022-2-9 15:52:32 | 显示全部楼层 |阅读模式
Serial number LE283009The short story is that it was blowing coolant hoses and I had to remove the coolant pump and reservoir. I found a plugged fitting, cleaned that out, reassembled everything and now the coolant pump/radiator fan run all the time....until you strike an arc. A few seconds into the arc, the coolant pump and fan shut off. When the arc is stopped, a few seconds will pass and then the coolant pump/fan start running again. It's opposite of what it should be doing.I can only guess that I either got two wires reversed, or didn't get fully reconnected, or that a wire got unplugged during reassembly. There's basically no room for visual inspection without taking the coolant reservoir back out.Thanks for any help.
GMT+8, 2025-12-18 18:00 , Processed in 0.141484 second(s), 18 queries .
