1957 shorthood ocv
发表于 2022-2-9 15:52:27 | 显示全部楼层 |阅读模式
Hey guys just wondering if my machine is set right. I checked the rpm’s and set them around 1400 rpm. When i check the voltage at the plug, it reads ~120 volts. I’m reading 84 volts at the studs and this is with the machine set at 3rd gear and 100. I checked the rack for a punch mark and it’s set on the punch mark. The machine welds fine but I’ve read ocv should be around 89. I’m just wondering if I have to bump the rack?? TIA
GMT+8, 2025-12-18 17:58 , Processed in 0.070966 second(s), 18 queries .
