1966 Idealarc 250 plug replacement
发表于 2022-2-9 15:52:24 | 显示全部楼层 |阅读模式
Hi, I’m very inexperienced in electrical work and welding. I recently picked up an old 1966 idealarc 250 that appears to be in good condition despite its age. The only fault I could find was a smashed power plug. I was wondering what kind I should replace it with? Machines input calls for 230v-70 amps but all I can find is a 50amp 3 prong plug.
Reply:the 50 amp 250 3 prong will be fine w/ a #6 cord , cuz  u wont be pulling 70 amp continuously, if at all
Reply:thanks for letting me know! Much appreciated
Reply:Easy install with most of the 6-50P plug ends. Most open up clam shell style and wire go straight up inti the set screw lugs. You will have no trouble. You will never even get that plug warm. When you aren't actually burning it is resting.  Haven't used one so no idea of quality or ease of installation but neat with pull handle.https://www.amazon.com/Miady-Groundi.../dp/B0894LVVWXCheapo,https://www.amazon.com/dp/B08DFQ7JN9...-viewed_5809_1Not so cheap,https://www.amazon.com/gp/product/B0...BYTMJMLD&psc=1Last edited by danielplace; 2 Days Ago at 07:35 PM.
Reply:Its worth a note,,, that this will work fine but I might be tempted to see if it ran from a 50.  Only reason is youy have tailored an outlet for this machine at 70A,,, its a 50 outlet and not for general use with other factory 50 cord and plug machines.www.urkafarms.com
Reply:Just as general info,,, this machine does not come factory plug and I even tend to bet its 8 wire in pipe machine.  Its not really sposed to be wired with a cable.  Cord maybe, cable no.Last edited by Sberry; 2 Days Ago at 08:00 PM.www.urkafarms.com
Reply:Right or wrong....My 1966 idealarc 250 is wired direct to the garage sub-box on a 100 amp breaker... Smoke em If you got em, boys...
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Thats kind of the way you are sposed to do it.  Depending on the model could customize the breaker or it might even be correct, prolly doesnt make much difference in the end.Last edited by Sberry; 2 Days Ago at 08:18 PM.www.urkafarms.com
Reply:I am not as familiar with the details to the exact models as might be for a Miller but they are similar.  A couple of the 250 feeders have a minor difference but not exactly sure about the Ideal/Dials.    Not saying I havnt done it other ways or even that I wouldnt but if I wanted a code legal install that would pass forensic would use a flex tube, AC type whip with 3 number 8, one of them green to a Jbox or panelboard with a 70.  Should add,,, or to other means of disconnect if the breaker wasnt local.Last edited by Sberry; 2 Days Ago at 08:37 PM.www.urkafarms.com
Reply:Some machines in this class allowed about 75 ft @ 208,,, ha,,,, anywhere south of that at 240 and you are golden.www.urkafarms.com
GMT+8, 2025-12-18 18:01 , Processed in 0.095274 second(s), 18 queries .
