Hot Water
发表于 2022-2-9 15:52:22 | 显示全部楼层 |阅读模式
hot water heater on 30 amp dryer outlet as a plugin is that possible.  i hit return instead o shift.   please give me time to re-enter my question.  thanks.Last edited by duramax-rob; 16 Hours Ago at 11:10 AM.lincoln 125spdayton 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dkubota b3200 FEL BHof course duramax diesel
Reply:Yes. Some will argue that the WH must be hard wired but I disagree, in fact we have a whole subdivision here where the WHs are plug and cord into a 3 wire dryer receptacle. The plug and cord qualifies as a service disconnect.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:I would say I fundamentally agree that in principle there is nothing wrong with it except that,,,, its never in the instructions to wire them that way due to the fact says cords not to replace permanent wiring.  Some will argue that the WH must be hard wired
Reply:As long as it is a tank type with less than 7000 watts it will work.A whole house instantaneous water heater will pull at least 50 amps so it would not work on a dryer outlet.Why do you need to heat hot water?
Reply:"so the burnt wire could be the result of possible water dripping on heater and small wiring."No. The burnt wire is from a "bad connection".
Originally Posted by Sberry
I would say I fundamentally agree that in principle there is nothing wrong with it except that,,,, its never in the instructions to wire them that way due to the fact says cords not to replace permanent wiring.   so,,,, I guess I do disagree,,, how much a risk is a different question.
Reply:Mine has a 30 amp 240 plug three wire  on it. It needs to sized to your WH. Don’t get a three prong RV 120 volt plug it needs to be a 240 plug.
Reply:My WH is 240 volt.
Reply:yes, the water heater is 240v and the dryer receptacle is 240 volt on a 30amp breaker.  i would like to use the 240v 30amp dryer receptacle so as to have the water heater on 10ga wire, 30amp breaker circuit.  i would just from water heater run 10ga wire and wire that to a 30amp plug which would plug into dryer receptacle.  that sound doable ???lincoln 125spdayton 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dkubota b3200 FEL BHof course duramax diesel
Reply:The instructions don't say you can and they don't say you can't, in fact most of the time the instructions say to have a licensed electrician install.
GMT+8, 2025-12-18 17:56 , Processed in 0.108541 second(s), 18 queries .
