Do 20 lb propane cylinders use back seating valves?
发表于 2022-2-9 15:52:22 | 显示全部楼层 |阅读模式
I always assumed the small 20 lb BBQ and RV cylinders used back seating valves and I can find some confirmation and opinions either way but nothing from an official source.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:The propane type valves typically is all on so seat does not leak. But could have changed over the years to a better valve.  You need to see if your valve want to be fully on. Dave
Reply:FYI I use the 20lb exchange tanks and have filled at the gas station.  Exchange when the tank is out of date or the valves leak. Dave
Reply:I am not sure how much the ones I saw today at the exchange really were, the sign says 15# and the 20$ price sign was well scratched over.  The supply hose finally sprung a leak after 25 years or so and I had nice chunk of copper line on hand to replace it.
www.urkafarms.com
Reply:This guy is probably more of a lesson in what not to do, but it doesn't appear to have back seating.... Last edited by whtbaron; 1 Week Ago at 04:36 PM.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I watched that video of the guy taking the valve apart and there are two orings so I wonder if one oring seals the stem in each direction?Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Not sure... I was wondering the same thing.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Why not call a place that provides propane to residential and industrial customers and ask them??  Or better yet, a company that makes the 20# tanks???
Originally Posted by danielplace
Think about that question for 1/2 second. Nope they DO NOT have to be back-seated. Lol. "Darn it, seems the wife only opened the barbecue tank valve 1/2 way and lit it 20 minutes later and blew the back of the house out"..
That is the likeliest reason they don't need to be back seated as how could you make that a requirement for the general public who is not even smart enough to know you don't get in and out of your vehicle when fueling? I was only wondering if perhaps one did leak a bit at the stem if back seating it would stop it. I have one now that leaks when opening but seems to stop when fully open, at least I get a big whiff when opening it that goes away once opened. It's very old and expired and is just about empty, will give it to Blue Rhino for a fresh one soon.
GMT+8, 2025-12-19 03:20 , Processed in 0.069465 second(s), 18 queries .
