Car explosion...Acetylene tank in trunk
发表于 2022-2-9 15:52:22 | 显示全部楼层 |阅读模式
It would be interesting to know the ignition source...https://www.yahoo.com/news/sonic-wor...182715316.htmlA Sonic worker would have been in the front seat of an exploding car if his nose hadn’t led him out of danger, Texas police told news outlets.The employee was about to head home around 11 p.m. on Friday, Jan. 28, after his shift at a Sonic restaurant in Houston, police told KTRK.But when he sat down in his car, he immediately noticed a strange smell, the TV station reported. It smelled like some kind of gas, police said.He rolled his windows down to air out the odor, then stepped out of the car — a fateful choice, as the vehicle blew up just after he exited, police told the Houston Chronicle.The blast could be heard for miles, and sent debris flying over the Sonic and elsewhere, KPRC reported. Parts of the car were found over 100-feet from where it was parked.The employee was taken to a hospital with minor injuries, police told the outlet, adding it’s “a miracle he survived.”Investigators say a leaking ox-acetylene tank in the trunk of the car likely led to the explosion, outlets reported. The Sonic worker apparently has a relative who does welding and left the tank behind.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:Wow, that's nuts, I wonder if it was a pressure situation or if the kid lit a smoke, who knows, fortunate to be alive.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:Dome light set it off?Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:That very thing happened to a good friends wife back in the 80's.  My friend and his wife had been to dinner the night before and he had stopped on the way to pick up a bottle of acetylene for the next day, he put it in the trunk of the car.  The next day he went to work and remembered the bottle in the trunk.  He called his wife to get it out and put it in his shop.  She opened the car door and the glove box and pushed the trunk open button and the car exploded.  The car was parked next to the house and the blast took that end of the house off.  She lived 3 days.Owner of Fast Leroy's Bar and GrillLiquor up Front, Poker in the Rear
Reply:Sure sounds like maybe a light or something similar....scary!Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:So,the regulator was left ON and possibly a leak in the hose or torch? If not, how often would a tank valve go bad?    pretty rare I'd think...
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I had two acetylene tanks in a row with bad valves.With valve closed, gauge would creep up in 5-10 min.The next tank they gave me was a different type (knob type valve, no square socket t-wrench thing needed)andI’ve never had a problem since.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Originally Posted by G-ManBart
It sounds like the relative put the tank in the trunk and the valve probably wasn't closed completely.  It would seem unlikely someone would put a tank in the trunk with a regulator still mounted...although certainly possible.
There aren't enough details to be certain, but there was no mention of a regulator being involved.  It sounds like the relative put the tank in the trunk and the valve probably wasn't closed completely.  It would seem unlikely someone would put a tank in the trunk with a regulator still mounted...although certainly possible.
Reply:Best Forth of July ever. https://www.kansascity.com/news/loca...252592578.htmlBest Forth of July ever. Sincerely, William McCormickIf I wasn't so.....crazy, I wouldn't try to act normal, and you would be afraid.
GMT+8, 2025-12-18 17:57 , Processed in 0.087514 second(s), 18 queries .
