Just wanted to share this project I build, it's a nice compact folding metal workbench:I have a small garage and although I have a Miler 30FX Arcstation, I needed for metal working space than I had and my primary workbench is steel. This was the solution, works great even if it's not a full fabrication table.
Reply:Works for a small area
I have a 3/16 top on my welding table, and it works fine. Heavier frame, but I have the area for a larger dimension, heavier, frame. Don't see any problems with your. I don't imagine you pound on it, so it's absolutely perfect for the use it's being put to.
Reply:Looks great 👍 Dave
Originally Posted by #1SomeGuy
Just wanted to share this project I build, it's a nice compact folding metal workbench:I have a small garage and although I have a Miler 30FX Arcstation, I needed for metal working space than I had and my primary workbench is steel. This was the solution, works great even if it's not a full fabrication table. |
