What uses have you found for an Ultrasonic cleaner in your shop?
发表于 2022-2-9 15:52:17 | 显示全部楼层 |阅读模式
Thinking of getting one off Amazon.  Not sure how useful it would be.  Will it clean oil and grease off of parts completely so they can be welded?With the appropriate chemicals will it remove mill scale, corrosion, paint?The first use will be cleaning carbs and chainsaw parts.  Also have bunch of things around the house that have lime buildup: faucets, sink strainers, pet bowls, etc.  Is it safe for gun parts?Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:I have a cheap one from Amazon and use diluted Simple Green...seems to work pretty well.  I use it to clean/degrease tools and gun parts mostly and find it to be handy to have.  I doubt you'd be able to find a combo that would remove mill scale or rust, but I guess it's possible.  With the right chemical it probably would remove paint.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:What G-ManBart said ^The solution you use makes the biggest difference. I've used purple power in mine. The heat option really helps too (at least for me since I use it in the winter).I used mine for cleaning chainsaw parts, which worked pretty well.GlenHobart Champion 16Hobart Hefty CC/CVHobart Handler 140Lotos LTP5000D
Reply:The contamination and base material help to decide what solution to use for cleaning.We have two ultra sonic cleaners here at work that I was using this week.I use a vinegar solution to remove some corrosion from items and also a simple green solution on other items.The first pic is kind of a before and after of some brass items in the vinegar. I also then rinse and do quick wire wheel.The big cleaner in the third pic has a heater. That will make it faster but cost more.Vinegar will remove mill scale and rust in steel but don't use it on other metals.
Sent from my SM-G996U using Tapatalk
Last edited by psacustomcreations; 1 Week Ago at 02:31 PM.Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Originally Posted by psacustomcreations
We have two ultra social cleaners here at work
Originally Posted by ArcTan
   where would we get our entertainment from if we didn't have auto correct!
Reply:How would it work on solid brass and brass plated items?Eg: mini blowtorches Sent from my iPhone using Tapatalk:
Reply:I own several commercial grade units. They are great, especially on carbs and gun parts.As others have mentioned using the right solution is key.Beware of the cheap ones. They don’t do that great of a job. A used one from a dentists office is the best balance between cost and power.Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Reply:tagged ultrasonic cleanerI'm tagging this because as we shut down the family business I will be acquiring an ultrasonic cleaner. It is rather large, I'm guessing the tank will accept an item 4' x 2' x 8". I too am wondering what uses are for a welding/repair shop?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!
" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-19 06:36 , Processed in 0.040950 second(s), 17 queries .
