Evolution 14” metal saw
发表于 2022-2-9 15:52:15 | 显示全部楼层 |阅读模式
Hey gang picked up a Evolution Metal Saw. Let me tell you it’s awesome. Was looking at different cutoff saw solutions. Those using abrasive discs are less expensive however they do throw a shower of sparks. This carbide blade barely throws any sparks and cuts straight. Had some old roll cages from Razer UTVs. It was easy to trim out all the straight pieces. Have all the bends in a box. Left some of the bunges on the tubes to make bolting together easy. Going to make a nice tube bumper and brush guard or something.  This saw is a beast, made pretty easy work of 5” 1/4” thick pipe cut on 30 degrees.
Reply:Nice saw I like the one I have, never like the fumes for the abrasive wheel, only use a cutoff wheel when I have to.You may want to look back about about a year guys posting where to have the blades resharpened and teeth replace for a good price.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:What brand saw do you have?
Reply:same as yours but a few years olderDIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:I have the MK Morse saw. I bought it off a buddy, new in box, and for a great price. Still in box, waiting to be put to use in new shop. Hopefully soon. I've used the same model on a job site. It worked fine. I might have gone with an Evolution had this not been a great buy."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!
" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I purchased Evolution couple of years back, works great. Does throw some chips, but i agree, way better that abrasives. Never could get the 14 inch abrasives to run true. Kept flexing.Search for posts by Oscar, his thread has address of sharpening shop just east of st louis in illinois.. Great sharpening shop and quick turn around.GeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
Reply:I got the Fein Slugger chop saw. The base is more robust the the Evolution. Built a rolling cart for it that works greatSide in down position
Side up
Fully extended
Cut a hole in the table top and added a chip tray
Last but not least swapped cord ends and installed 50' cord real
Reply:I have used several different blades, I like the DIABLO STEEL DEMON, # 1472CF,  blade the best. I get a lot more cuts from these than all the others I've tried.
Reply:Wow that’s a nice table setup.
Originally Posted by oldgrandad
Thank you, I've made 6 of these carts so far, for our service techs and other shops. The fold down material supports make it easy to transport and give it a much smaller foot print when not in use. I like to have everything on wheels. seems like no matter where you put it, it is in the way. Oh wheels at least you can move it.
GMT+8, 2025-12-19 05:39 , Processed in 0.089429 second(s), 18 queries .
