Manual TIG Feeder
发表于 2022-2-9 15:52:13 | 显示全部楼层 |阅读模式
Not sure if any would be interested but I found a video showing this manual Tig Feeder, and bought one, have not used it yet but I needed help with the feeding the puddle.
   There is a video in the ad.   If you buy one you will need Dynomite to get it out of the plastic wrap.
https://www.amazon.com/dp/B08GQJ1MK9...roduct_details
Last edited by acourtjester; 3 Days Ago at 05:02 PM.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:If u can use that you can feed wire without it
Reply:It does look like the same motion I sometimes use to feed? Let us know how you like it?
Reply:Just start welding aluminum you will be a pro soon at feeding the rod
Reply:CK also make a tig rod feeder.  called EZ DABRlincoln 125spdayton 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dkubota b3200 FEL BHof course duramax diesel
Reply:Understand the hand movement you are talking about, and I do weld aluminum for some time now.  But it is hard to teach an old dog (78) new tricks, moving my thumb is easier for me then 3 fingers.
Originally Posted by William McCormick
I don’t wear a left glove never did for TIG. Some of the Miller machines will give you a nice one if you bond the rod to the tungsten, but it only happens once very 20 years. Sincerely, William McCormick
Reply:Looks about as much use as this, but less funhttps://www.amazon.co.uk/Maijia-Crea...2s9dHJ1ZQ&th=1Murphy's Golden Rule: Whoever has the gold, makes the rules.
GMT+8, 2025-12-19 05:34 , Processed in 0.169520 second(s), 18 queries .
