2004 lincoln classic 300 g trouble shooting help needed can anyone help?
发表于 2022-2-9 15:52:08 | 显示全部楼层 |阅读模式
I have a 2004 lincoln classic 300 G  thats starts up fine,  it runs about 10 minutes or so & then starts to cut out & goes to a very low idle.  If you hit high idle it does not idle up nor will the 110 power plug make it idle high.  The plugs work electrial tools until the running issue starts.  I have cleaned the gas tank out , new filter ,gas.  it is getting fuel. PC Board?
GMT+8, 2025-12-18 20:53 , Processed in 0.112439 second(s), 18 queries .
