Connector name
发表于 2022-1-25 15:51:15 | 显示全部楼层 |阅读模式
This two wire connector goes to my TIG Button controller. Late yesterday I pulled the wires out so need to replace it or fix it.What is this type of connector called so I can look for a new one. The company is not open yet and I can call later, but if I can find the name I can order the part myself. Thanks
Sent from my SM-G996U using Tapatalk
Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:i don't know the connector name but usually there is a tab that is suppose to stick up from the metal end facing the wires and prevents the wires from pulling out.  pry this tab up and reinsert.lincoln 125spdayton 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dkubota b3200 FEL BHof course duramax diesel
Reply:Stress relief if is for electrical. The photos did not show up until postedThat is a plug used in electronics some are custom by company. I save the parts and hope it works. The barb can be found in bags try a computer repair to buy a hand full of size you need.Dave
Reply:FYI the plug part is not need but barb can be plugged in with out the the plastic plug.Dave
Reply:Looks like a Molex connector to me, with a locking tabMiller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:That was a tough one to locate.These are what they are using I believe. 6 months to get them. Lol. Lets go Brandon.   https://www.digikey.com/en/products/...3957-2/1152435I would solder them in cleanly and heat shrink them and call it done.Last edited by danielplace; 12 Hours Ago at 03:40 PM.
That looks just like it. Many thanks. I reached out the manufacturer of the Tig Button and am trying to get them from him. The problem is in trying to plug this end back into the control box.
GMT+8, 2025-12-19 05:33 , Processed in 0.112978 second(s), 18 queries .
