Small clutch housing removal
发表于 2022-1-23 15:51:26 | 显示全部楼层 |阅读模式
Working on a project where I need to remove the black outer housing of a clutch to change a fit up. I didn’t know where to post this, so I was wondering how I should go about this, as the nut on the inside is welded on or something. I was wondering if just cutting off the housing all together would work. Thanks.
Century FC-90Primeweld TIG 200D
Reply:Sometimes they are reverse rotation threaded, when in use it tightens up.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:The bearing in a riding mower electric clutch fails often.The assembly is staked in a manner that it is designed to be tossed, and replaced.Rather than replace the entire clutch assembly, the mower guys have figured out how to grind away the stakes, and re-stake after the bearing is replaced.This may be a similar item, considered disposable,, Check YouTube,, for the answer,, I do not know what the item is for,, so I can not search,,,,,,,,,,,,,,,
Reply:Could be that by pressing on the pinion end the clutch drum and bearing comes out the rear.
GMT+8, 2025-12-19 05:33 , Processed in 0.076856 second(s), 18 queries .
