Linde heliarc 250hf won’t start a puddle
发表于 2022-1-22 15:51:16 | 显示全部楼层 |阅读模式
I’m new to this and bought a l-tec 250hf the guy showed me it worked and is a buddy that offered my money back if it doesn’t work.  However I can get the arc to start but then it looses it and won’t start a puddle I hear about checking the gap but I have no idea where to set that and I can’t find a manual anywhere
Reply:send me your email by private message.There are two weak points that will cause you a lot of grief. There is a small relay on the control pcb (one of two) that turns the HF on and off. They fail.I have also replace the HF cap on the HF assembly. Plus I have resoldered all the connects on the HF assembly pcb. The Miller HF cap will bolt right to the pcb. It is a better fix than trying to get one from ESAB.  Yellow or green a heliarc 250/350Hf machines are the same. PCB is obsolete but HF parts can be had.learn how to use a multimeter tester safely and we can fix this welder.
GMT+8, 2025-12-19 05:34 , Processed in 0.097335 second(s), 18 queries .
