Long shot but..... anyone good with Old Lincoln Idealarc guts?
发表于 2022-1-20 15:51:35 | 显示全部楼层 |阅读模式
A common issue with the SP200 is smoking the choke and I’m currently having the issue. I don’t know the specs to go looking for a replacement. If anyone has them I’d be grateful. Also, i have an idealarc 250 that has a larger choke that probably wouldn’t be the right one to use in my sp200, but since i have 2 of them I’d chop one up to use and get my mig back going. I’ve seen the chokes in both and the 250 is definitely larger and a different winding.
   Lincoln 210 MPLincoln 180 Mig Lincoln 3350 2.0 CK CK17FV CK CK9FV
Reply:You need a MIG choke not a stick choke.Just find another 200 amp mig and use its choke.But i would rebuild the cap bank. bad capacitors may be causing the choke to workto hard. Or just running it to hard to long. Not watching the duty cycle limits.If you can find the right size magnet wire, you might be able to unwind the old choke and wind new wire on the choke frame with same number of turns.
Reply:Why would you molest a working Idealarc 250. The cables look pretty small on it though.
Reply:I agree with Welder Dave, leave the late model 250 alone.  And the bigger leads is a good suggestion as well.  You might call Stumpf’s In Mascoutah, Illinois. Ask to speak with Jim, he’s been there since the early 70’s, for advice on repairing your welder. Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:By the way i knew this post existed about a year ago because I anticipated this happening eventually https://weldingweb.com/vbb/showthrea...bly-for-SP-200Unfortunately he hasnt been active in 5 years so getting any further info is out.   Lincoln 210 MPLincoln 180 Mig Lincoln 3350 2.0 CK CK17FV CK CK9FV
Reply:You could sell the 250 for a decent price instead of robbing it for parts. Not much comparison between a 225 buzz box and an Idealarc 250. The stinger lead on a 225 is only 15' long.
Originally Posted by one1
cables look small because the unit is huge
Reply:the part in the picture is not a choke. it is a mag-amp.the burnt plates are the aluminum weld conductors. look real close, there are three sections. two with large flat wires and one in the middle with fine wire. The fine wire coil is driven by the pcb. Current in this coil allows current in the other two. Better test your weld diodes you might find a shorted one or two. same with the cap bank, check for a shorted or bad capacitor. Might be able to get one from an old R3R, R3S. three phase welders that have three of these. That might be adaptable. should be able to find for scrap metal cost.
Reply:As you can see it’s getting crowded in here. The 40 lb roll of wire is brand new as is the liner. Just get that fixed and get back to burning.
Reply:I think the mag can be rebuilt. It only smoked one side. The rest of the machine is excellent.
Reply:Here's why i said it looked rebuildable. The center coil is fine. It was just the outside finsink winding.
Reply:#4 cables limit the output capability on the 250 Idealarc. They are too small. #4 is only rated to carry 180 amps at 100feet and 30% duty cycle. I run #1 size cables on my 250 Idealarc.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Did you ever get this going?1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
GMT+8, 2025-12-18 22:05 , Processed in 0.180204 second(s), 18 queries .
