Does anyone still build their own cnc plasma table anymore?
发表于 2022-1-17 15:51:19 | 显示全部楼层 |阅读模式
Im in the dreaming stages of a cnc cut table, i do have a local shop that will cut for me quickly but still a day plus and as i get older i shake worse and cant see as well, and the freehand cutting ability is getting worse. so im dreaming of a table something i could put a 4x8 sheet on and also run oxy on i have been watching auctions and tables seem pretty steep for old electronics A new one is in The 25000 range easliy. So anyone build there own? and what software and hardware systems work well together?. Im a non electrical inclined person but i can figure it out though going to have to learn it eventually though.Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:Check out member acourtjester. He gas made a bunchSent from my SM-G996U using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:Been trying the search but not working for me used to be a lot of build threads to research throughDo not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:What are you wanting to cut?Dave
Reply:There is always these things. Disclaimer-I don't have one. I've never used one nor seen one in the flesh. I don't know if they are any good  or not. Just another option. Others will have opinions and if you(we) are fortunate maybe someone has some actual experience with one. Oh yes, I am not affiliated in any way with the manufacturers or the vendors. https://www.amazon.com/Portable-Effe...%2C605&sr=8-11---Meltedmetal
Reply:Yes I have made 9 tables and am working on another, If you send me a message from here I will help you with the info you need.  You can build a table for the price of the amazon cutter, Plus the plasma unit.  If you can follow instructions it is not hard and there is plenty of help from other too.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:idacal, check out 'My 5x10 plasma table build' here on WW by Pugs_.  I don't know if this qualifies for the "still build ... any more" 6 years later part of your question, but it's a build I bookmarked for future reference.https://weldingweb.com/vbb/threads/5...ma-table-build
GMT+8, 2025-12-19 05:32 , Processed in 0.112368 second(s), 18 queries .
