Migmatic 273
发表于 2022-1-13 15:51:19 | 显示全部楼层 |阅读模式
I have recently acquired two used Miller Migmatic 273 mig welders. They are supposedly both functional, but I haven't had time to test them yet.
The first unit seems to have all the original parts and wires still factory tied together. But I noticed that the board in the front with an LED display board is missing. I assume that the board was removed for some odd reason. Another thing that stood out was the broken contactor. Someone must have pulled on the power cable a little too hard and broke the contactor case.The first unit:
Reply:The second unit seems to have had the control board replaced with an aftermarket one. The cables are all a mess and the potentiometer for "Spot Weld Timer" has its wires cut. However, the LED display board is there.The second unit:
Any comment or recommendation by anyone using this welder would be welcome. I hope I find some time to test both units over the weekend.
Reply:The first thing needs a good cleaning.The basic are there It three phase too.Dave
GMT+8, 2025-12-19 05:33 , Processed in 0.065474 second(s), 18 queries .
