Miller foot pedal parts list
发表于 2022-1-11 15:51:22 | 显示全部楼层 |阅读模式
I need to replace the two capacitors in the foot pedal and I dont have the pedal part number handy. It's similar to the RFCS-14 with the 14 pin plug.  Also, just incase the potentiometer is bad, can I get a source for that also?
Common sense in an uncommon degree is what the world calls wisdom.
Reply:Go to millerwelds.com and find the owners manual. miller parts list is in the back.The miller potentiometer should come with the caps on it.Caps by them selves can be purchased at any electronics store.
GMT+8, 2025-12-19 05:38 , Processed in 0.092623 second(s), 18 queries .
