Broken Screw Removal
发表于 2022-1-9 15:51:22 | 显示全部楼层 |阅读模式
For this project I removed a screw that broke off from a rotor of a washing machine for my friend John. 1. Broken screw
2. Wire brushing area
I welded an extension to the broken part of the screw that was still stuck in the rotor.3. Me TIG welding extension to broken screw
4. TIG welding extension to broken screw closeup
I removed the plating on the nut, by soaking the screw in Hydrochloric (Muriatic) acid.5. Soaking in HCL or Muriatic acid
Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE  31 MP & Lincoln 210 MP
Reply:6. Nut welded to screw extension
7. Broken screw removed
8. John cleaning up tapped hole
9. Closeup of tap in hole
10. New screw installed
-Don
Reply:Good job, and don't forget the antiseize.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-19 05:40 , Processed in 0.097766 second(s), 18 queries .
