Welding
发表于 2022-1-9 15:51:22 | 显示全部楼层 |阅读模式
Can welding with a flux core and a stick welder at the same time on the same piece of metal be done without hurting the machines or the welders using them
Reply:Why would you do that?Dave
Reply:Because I need two people welding and those are they only two welding machines i have
Reply:I agree with
Freebirdwelds
yesDave
Reply:Heck yes, I've been on pipeline work with 8 machines at one time hooked up to the pipe.
Reply:I have metal girders that I am wilding reinforcements on that are all connected by a metal roof so if I connect the ground clamp to one girder I can weld on any one of them. If I have a smaw and a fcaw i have two different polarities. I don't want to use both of them if it's going to hurt my machines, who's helping me or myself
Reply:Ok thanks I appreciate the info
Reply:It is done all the time in shipyards, fabrications shops and large construction projects.ChrisAuction Addict
GMT+8, 2025-12-19 05:35 , Processed in 0.073605 second(s), 18 queries .
