Tails on filler rods
发表于 2022-1-9 15:51:21 | 显示全部楼层 |阅读模式
Some of my first Dozen AL beads with filler rod after the dots and non-filler drills….I dialed down the amperage from 145 to 125a. 65% EN, 120hz. 3/32-4043The foreground coupon is the newest drill….Reason for post: I notice that my filler rod will sometimes develop a small spindly tail. Is this because I am very green and that I am dragging the rod in and out of the puddle?
Reply:Yea if it's not a deliberate fast dab-n-pull it can dribble and leave ugly dross as it oxidizes from only being partially covered by shielding gas.
Reply:Thanks…..
Originally Posted by William McCormick
When my father taught me to weld, he said it is better to make one good bead than a bunch of nasty ones. So he would make me do one bead and stop, or at least come off the heat and then make another bead and stop. And before you know it learning the proper technique in slow mo I realized that I was actually preparing to learn it in high speed mode. I did a lot of aluminum railings and a lot of aluminum welding and it was that early one bead at a time thinking that allowed me weld so fast later on. I would not worry about how the overall looks just make sure you can make one nice bead add your filler, lower the heat move a very small amount forward and do it again. Sincerely, William McCormick
GMT+8, 2025-12-19 06:58 , Processed in 0.251109 second(s), 18 queries .
