Engine drive compressor remote.
发表于 2022-1-7 15:51:19 | 显示全部楼层 |阅读模式
Made a remote start for the compressor while I'm on vacation. At least now I don't have to climb the side of the truck to start/stop the compressor. Works great, high throttle till 180psi and then kicks back on @ 160psi. I'll probably have to retune the Pilot Valve when the hot weather comes back. One of the 3 safety valves will blow at 200psi. But for now I'm loving it..
Last edited by Freebirdwelds; 10 Hours Ago at 05:33 PM.Reason: SpeelingLincoln 330 MPXModified TombstoneLincoln LN-25X-TVTMagnum PRO 250LX GT Spool Gun¼ Ton of Torches OFC-A / OFG-ASMAW FCAW GMAW Air Carbon Arc Gouging#Freebird Welds
Reply:Just speaking from experience here, I would replace the long nipple and copper tube with nylon air brake tubing, that copper stuff does not like vibration. Otherwise I like it. I've always set my trucks up to run everything from the ground.
Reply:Mine has remote also.  Can run it from the work side.www.urkafarms.com
Reply:Looks great 👍 Do you ever miss pulling the rope ?Dave
Originally Posted by smithdoor
Looks great  Do you ever miss pulling the rope ?Dave
Reply:tagged compressor remote panelHoly crap! Just two days ago I searched the internet like crazy trying to find a remote panel for an air compressor! I even called aircompressorsdirect.com and asked them with no luck. Very cool. I just might PM you in the future for questions. I got a line on a Champion compressor, for free
, but I have to make a run out to Virginia to snag it!
Very nice work. Can you give a tour of your truck?
Last edited by Stick-man; 2 Hours Ago at 01:06 AM."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!
" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2025-12-18 20:53 , Processed in 0.118093 second(s), 18 queries .
