Help with welding trailer layout
发表于 2022-1-6 15:51:19 | 显示全部楼层 |阅读模式
I bought a ready built welding trailer. I am trying to understand the logic of the bottle rack.This is what it looks like in what I presume is the intended usage position.
If you pull a pin it folds flat like this. I presume this it to make loading and unloading the bottles easier?
Finally it can stand vertical like this but there is no way to secure it in this position.
I am thinking of welding the rack permanently in the vertical position. It doesn’t seem like it would be too hard to load that way, and it frees up a ton of space on the trailer. I know the acetylene can’t lay flat but aside from that what am I missing on this setup? The manufacturer obviously put a lot of time, effort, and expense into making this rack pivot every which way but I can’t see what benefit it has over just being perfectly vertical.
GMT+8, 2025-12-19 05:38 , Processed in 0.093975 second(s), 18 queries .
