A380 Die Cast & 6061
发表于 2022-1-5 15:51:28 | 显示全部楼层 |阅读模式
Is it possible to weld A380 to 6061?  Specifically I have a unique configuration part that requires a "lid" to be welded to it.  The unique shape is A380, while the flat lid is machined 6061.  Just wondering if it's possible?  Thank you in advance for all your expertise!
Reply:MKinsey,A380 is a weldable cast aluminum alloy.  I believe it would weld to 6061 without issue.  I am not sure of the strength properties after welding.  If a low strength solution would work for you, I would try it with 4043 or 4943 rod, and just be careful with it.Geoff
GMT+8, 2025-12-19 05:34 , Processed in 0.099731 second(s), 18 queries .
