Dynasty 200DX probs
发表于 2022-1-4 15:51:24 | 显示全部楼层 |阅读模式
My DX is playing up. Got rt showing on the volt screen and peddle doesn't work. Works ok in 2t with torch switch. rt isn't an error code, it's an advanced settings mode. Can't back out of it. Tried factory reset, no change. Cycled power etc. Nothing in manual about it.Any ideas?
Reply:I suspect it might be the wireless peddle dongle. If I switch to remote std with my torch switch connected I don't get the fault.
Reply:If you still have a wired remote, try it. If works ok then you are on the right track.With miller wireless remotes. change the batteries then open the foot control. Take bottom off. Clean all the dust and dirt out of it. Some times the metal in the dust interferes with the radio transmission to the receiver.
Reply:Already changed the batteries, but giving it a clean is gotta be worth a go. Thanks for the tip.
GMT+8, 2025-12-19 05:34 , Processed in 0.090227 second(s), 18 queries .
