Galvanized
发表于 2022-1-4 15:51:21 | 显示全部楼层 |阅读模式
What’s the best way to avoid the flumes from galvanized pipe welding
Reply:put one of them old  "wooden clothes pin" on ur nose
Reply:Not welding galvanized would be the best way to avoid fumes. Otherwise, welding outside with wind or fan blowing fumes away.  Keep face out of the smoke.
Reply:Sand off the galvanizing at the weld joint. Weld away. Spray with cold galvanized paint when done welding.ChrisAuction Addict
Reply:Weld in a well ventilated area, wear a respirator.SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp AC
Reply:Best way is a PAPR with a gas filter, next best is be clean shaven with a P3 rated respirator, after that weld with lots of ventilation and keep your head out of the smoke and pray.
Reply:Stay upwind. Or hold your breath.
Reply:I have weld lot galvanized I simple welded out side and stayed up wind. I also a simple mask too.Dave
GMT+8, 2025-12-19 05:33 , Processed in 0.094342 second(s), 18 queries .
