Let's see the welding rigs
发表于 2021-12-29 15:51:21 | 显示全部楼层 |阅读模式
Show off your trucks and beds.  Pipeliner, oilfield, trailers, I just want to see what you got."I'd rather be careful a hundred times as killed once"
Reply:Well........ Since ya asked
It's in the partial completion stage
I'd say closer to partial
"Any day above ground is a good day"
http://www.farmersamm.com/
Reply:Samm - Wait ‘till you see there eyes, when we roll into the streets of Bakersfield!
Reply:Don't forget to paint it Miller blue Sam.
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Did pretty good on it actually.  Got a good tranny case out of it, rebuilt the insides.  AND I got a good set of hangers for clutch, and brake pedals.  And a good floor opening cover thingy where the transmission goes.  I may have to use the tunnel too.  Great swap for 7 bales of hay.I have a really good body that had an automatic in it.  So I'm hoping that I can rebuild the auto cab to accept manual trans. stuff.  GOOD LUCK TO ME SAYS I.Last edited by farmersamm; 02-23-2009 at 01:35 AM.Reason: spelling.... sway/swap"Any day above ground is a good day"
Reply:here's a couple pics of mine set up for plow duty.  the other one is the day after I got the machine mounted in the bed.  It sure is nice to have the machine in the truck for plowing,  the extra weight allows me to plow in 2wd and I even got to use it when another guy backed over a sign.
Local 597 PipefittersCertified stick and tig pipe welderLincoln Ranger 305g - for saleMiller 185 migMiller Digital Elite
Reply:Here's my trailermachine comes in and out for welding
Trailblazer 302 AirpakDynasty 200 DX
Thermal Dynamics Cutmaster 52 CamoMiller Dailarc 250 OLD But great!!2 Miller 140's w/autoset NEW!
Millwauke Cold cut sawsDewalt portabandJd2 notcherPipe beveling machine
Reply:Here a few of mine most have already seen it here,but you asked.
Reply:Here a few more,Nothing to fancy but i can get the job done.
Reply:Ok,
I guess I'll post mine just to cheer you guys up.Everyone needs a laugh at my expense to day...Go ahead...I know what ya'll are thinking but times are tough here.
So remember what I have the next time you think about complaining about yours.
Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Lugweld isn't that truck a little overloaded?
Reply:It sits fairly flat.  Its a Mitsu...It has REAL springs. The frame is boxed and super heavy.  But it is sluggish on the take off.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Well Lug don't feel bad... You have a truck
  I work out of a VW Jetta...
It amazes me how I can fit my Dynasty, all the cables, Oxy / Prop torch, 40ft argon tank, grinders, hand tools and usually a few small pieces of steel in there and still get down the road making money... I may move up to a Ranger one of these days ...mmmm.... a real truck...mmm
Reply:VW Jetta...one of the best cars I ever had.  Maybe you could trade it for a Rabbit Pickup...Had one of those too.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Lugweld, I have practically the same truck here, an '87 Dodge Ram50 longbed 4cyl/5spd.   I have been using it lately with my portable generator to get jobs done while my usual welding truck is at the mechanics.   Normally it's my run-around truck, but was my makeshift welding truck before I got serious about mobile welding and set up the F350 to do the job.   Generac 4000XL powering the Millermatic 175 in the back of the little Dodge is what I used on my first mobile gate repair.  The little trucks are tuff and seem to last for decades with only minimal maintenance.   I brought my Bobcat home in the little truck and kept it on there till I transferred it to the big truck for it's permanent home.  That little truck was riding low in the back with the Bobcat in it, but it handled it fine.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:"VW Jetta...one of the best cars I ever had. Maybe you could trade it for a Rabbit Pickup...Had one of those too."Yup it'll be real hard moving from 50MPG of the lil TDI but, after 300k she has paid her dues. I'm planning on keeping her as my daily driver just taking away the heavy work. I do have my eyes open for a rabbit diesel truck too,.. just real hard to find these days.
Reply:There ya go Lugweld, That's how to do it ABAC style if I've ever seen it!
  Here's a couple of mine.  Not good ones, but the only ones I can find on the hard drive.
I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:http://weldingweb.com/vbb/showthread.php?t=27867It's a work in progress...Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:I don't have a dedicated mobile rig, with everything (or anything
) set-up nice. That should go on the to-do list!Meanwhile, if I have to, here's how I'll  roll:Attachment 29019I lifted the tarp and touched the starter button, the Lincoln fired right up. So I guess I'm ready.The dog was worried about being left behind!
Here's the tool box:
Attachment 29020What would they say if  I rolled into the streets of Bakersfield... Not only lengthwise but squeezed left too!
PS - MAC702 - If #10's designated driver split, she can climb on the back.
Reply:heres mine.   Slow but does the job
Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I even run bakersfield fabulous when the welders on the trailer.I think im going to change my sig to "I dont care how they do it in the oil patch."Or "i dont care how they do it in  Wasco"Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Dualie - I think that's a '69 Caprice parked there... with spark burns in the vinyl top.
Originally Posted by lugweld
Ok,
Reply:Looks like a vinyl top but on closer inspection that's just bondo and krylonVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.Heres the pipe rig i just set up. The repair (KW) is hung up on a shovel job but will be back soon.
Air vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:Most of my work is done in a barn, but when i hit the road to do a job this is my favorite way to travel and haul my tools! pretty ghetto compared to some of you guys. id like to get an enclosed trailer to haul stuff around but this is a bit more comfortable.
only thing worse than an ugly woman is an ugly weld
I only need the gen. when I don't have access to 220. A real PITA to load by myself
Reply:Mine might not be as old as Samm's, but we have less rust in New Mexico
Reply:El_Lloydeo, isn't it illegal to carry cylinders in a trunk?  I could be wrong on this, but for some reason I remember reading that somewhere before...I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Hammack...Isn't that for Nitrous?
But you are right.   It is illegal for any type of highly compressed gas cylinder. Something were to happen, your car would turn into a self propelled missle.BTW Spaulding,Cab overs are nice.  Those who haven't had one don't realize the convenience they offer and economy of space.
Reply:This is my 1990 F450. 7.3 non-turbo diesel, 5 speed. Lincoln SA200, air-compressor, arc-air and air tools, LN25 feeder, oxy/acet torch, hand chain hoist, porto-powers, etc.. The other is my beat up old 91 Dodge cummins 5 speed 4x4 which will get her SA200 and torch as soon as the weather straightens up and I get my new/used flat bed put on!! OH, the little gold Wisconsin powered Hobart in the back of the ford goes in my red dodge 4x4 (in back-ground) for those muddy/ snowy situations. It is mostly used as a generator when the ice storms take our power out.
The first step to having everything you want is to want everything you have.
Reply:Helrzr1,I'm admiring the lifting setup in the back of your F450.  What sorts of stuff do you find yourself using the chain hoist on the I beam trolley to move?  Is it just for loading tools into and out of the truck bed, or is it useful for loading stock and customer equipment?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:here's mine
WELD IT RIGHT OR GO HOME!!!
Reply:Flux:Nice unit! I really like your welding cart, very clever.Farmersamm:Does that have a hemi in it??? Diesel or gas?
Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:cummins big 6.7 dieselWELD IT RIGHT OR GO HOME!!!
Reply:yeah it is illegal i think, but i doubt the cops in my town know that! it was about empty anyway though haha.only thing worse than an ugly woman is an ugly weld
Reply:OK!Mine is still sitting in the back yard waiting for me to start doing something with it!Its a 1991 F-250, 351ci and 5 speed manual, "Ex farm truck", the previous owner had the suspension re-done so it has the equivalent of a 1 ton suspension, I can load it down to the top of the cab with stacked fire wood, and it just makes it ride better!I plan on removing the bed and replacing it with a flat deck or a service body "when I can find one" and start from there!Ken.
#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:2003 F-550.  Bobcat 250. 1978 Lincoln SAE-300.
Reply:The one thing I don't like about cabovers is, if you ever get into an accident, your the first one there!
Reply:Nothin' Fancy; still working on it.
Reply:Hope this works here is my truck fully enclosed everything locks up
Originally Posted by vantageman500
here's mine
Reply:Will get one with the back opened up. It is a little heavy as its tread plate as you can see but it slides back to the halfway point and leaves a nice overhang to stay out of the weather or you can flip the back door over and stand up in the back third. From the rear the box on the right is an extension of the bottom cabinet. This is where the oxy/acet is and the hose real. You can't see it in the pics but there is a gen set on the drivers side behind the cab. This set up is heavy but it is a 450. Also a small hoist in the back on the drivers side that swings out.Last edited by flatbustedbroke; 03-01-2009 at 08:40 PM.
Reply:the hoist was easy. I cut down a cherry picker (engine hoist), mounted it to a front hub off Dana 30 I took out from under my Wrangler, recessed that into 6" pipe, cut a hole in the floor 8" out from the wall and 8" from the rear, added gussets under the floor. I will post the pics when I get back home might be next weekend.
GMT+8, 2025-12-19 11:54 , Processed in 0.092427 second(s), 18 queries .
