Weldanpower225 wont generate 110 volt or weld.
发表于 2021-12-28 15:51:28 | 显示全部楼层 |阅读模式
I have weldanpower225, that had a broken wire on regulator.I had a problem, with the high/low idle coil that I fixed. At the time I didn't know there wasn't any output, won't weld I haven't checked voltage output with meter.Ordered a set of brushes.
GMT+8, 2025-12-19 11:52 , Processed in 0.088058 second(s), 18 queries .
